Troubleshooting Hardware
Hantek
I'm trying to modify the existing SDK for my 6022 Hantek. Using the example VI provided with The SDK I am able to get readings. I am able to modify the sample rate, time base ECT.  Unfortunately the scale is 0 to 255 . I assume it has something to do with the 8 bit levels.  I do not have a copy of the VI as I'm at work on a mobile phone.  It's just driving me crazy.  Is there a way to calibrate or scale the program or scope to read accurately.  For example, a 2 volt square wave reads 25 volts.
Any guidance will help. I will post the VI when I get home
(951 Views)
Hello, Jesse47.
This is a sub-forum for FIRST robotics support.
I would suggest posting a thread in a more generic sub-forum like the active hardware boards sub-channel (https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Problem-with-running-Hantek-6022BE-driver-HT...), to get more eyes on your thread.
(945 Views)
