This document describes how to install LabVIEW under OpenSUSE 15.2.
Prerequisites
- You already have a working OpenSUSE 15.2 system or Virtual Machine (VM)
- You have purchased & obtained the LabVIEW for Linux .iso
Guide
- Close all NI software on your system if any is running
- Mount the LabVIEW for Linux .ISO (disk image file)
- This can be done using your VM software, and is similar to loading an .ISO as a DVD-ROM image when using a virtual machine for any other Linux or Windows OS
- You can also mount the .ISO manually by entering a few commands in the terminal (aka Konsole)
- create a mount point using sudo mkdir /mnt/LV2020
(You can also use the su command to switch to the super user/root account, enter your password once, and then you don't need to include the sudo argument each time, like I've done in the screenshots)
- mount the ISO using sudo mount -o loop /path/to/my-iso-image.iso /mnt/LV2020
- Navigate to the mount location and run the Install script
- Navigate to the mount folder using cd /mnt/LV2020
- Run the install script using sudo sh ./INSTALL
- Follow the terminal prompts to complete the installation
