SystemLink Forum
Using SystemLink to install low-level drivers?
I've been playing around with the Repository Manager, and I've successfully used the Systems Manager to install and upgrade Application Software packages.
Are there any plans to lets users install lower-level software (e.g. VISA) through SystemLink? (I understand that we can't install/uninstall the SystemLink client software through SystemLink itself)
Certified LabVIEW Developer
(3,293 Views)
Accepted by topic author JKSH
Yes, SystemLink 17.5 is set to release in a month or so and it will make it a lot easier to deploy drivers like NI-VISA and DAQmx.
In the meantime, you can do it by replicating a feed from ni.com like http://download.ni.com/support/nipkg/products/ni-visa/17.0/released to your local repository manager or just add the feed directly to the target from the Feeds tab on the Software view.
(3,284 Views)
