SystemLink Forum
Replicating feeds
My organization's IT prevents NI Package Manager from working properly.  I'd like to use SystemLink to replicate the feeds so I can use it to distribute packages internally.
I've been able to do this for one feed by going to 'repository manager'->'replicate'.  I'd like to do this quickly for the other ~75 feeds.  Is there a recommended process or configuration file somewhere that can be updated quickly?
-Steve
(3,610 Views)
Accepted by GreyGrey
Hey Steve,
There isn't a configuration file edit or anything that you could do but you could write a script that uses the HTTP API that Josh P posted to replicate all of the feeds. Specifically, you would want to use the /nirepo/v1/replicate-feed call for use with the Repository Manager.
Brandon Grey
Certified LabVIEW Architect
(3,583 Views)
