This document is part of the SystemLink Portal.
Configure SystemLink Server to Auto-Approve Clients
Use the following instructions to configure the SystemLink Server to automatically approve any SystemLink Client systems that connect to it. This can help you to scale the provisioning of a large amount of client systems because you no longer have to manually approve each client system in the SystemLink web UI.
Caution You should only turn this "auto approve" setting on if your SystemLink Server is on a trusted network where only trusted systems/users can connect to the SystemLink Server.
If you want to turn off automatic approvals later, then follow the above instructions, except change the auto_accept setting back to False.
For more information on the auto_accept setting, refer to the following SaltStack documentation:
https://docs.saltstack.com/en/latest/ref/configuration/master.html#auto-accept
