SystemLink Forum
When do Tag Aggregates work?
Using the snippet below, LV 2015, and the TagViewer web page, I read and write to two tags. But the Aggregate values on the TagViewer webpage and the Aggregates output on the VI front panel never change from 0's. (I write to one tag from the VI, and to the other from the TagViewer.) When are Aggregates supposed to get updated?
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Embedded Systems Developer
There are 10 kinds of people: those who understand binary, and those who don't.
(3,508 Views)
Accepted by topic author Dave_Thomson
You can confirm that you've enabled aggregates on the tag you are working with? Also, does your count column in the tag viewer display a number? When I have a tag that has never received a new value, all columns are blank as opposed to showing '0'.
Brandon Grey
(3,469 Views)
Yeah, I found where to enable them.  Thanks.
(3,465 Views)
Hello Dave
I would like to attach the document in the link below.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019SPkSAM (Skyline API Installation for LabVIEW)
Regards
(3,373 Views)
