SystemLink Forum
Webvi_plugin template required changes to avoid duplicates
I'm playing around with the webvi_plug template stuff from https://github.com/ni/systemlink-web-interface-template and I'm wondering:
  1. In which place I need to change the reference to webvi_plugin to avoid duplicate SystemLink dashboards in the web server configuration?
  2. Which references to webvi_plugin need to be changed to identify the dashboard with it's functional name in:
    • SystemLink portal?
    • Web server configuration application privileges page?
  3. How to rename e.g. the name of "52_webvi_plugin.conf" in the project and have it update properly in the distribution?
  4. How to add a file like "52_webvi_plugin.conf" to the distribution like the current one is done, I don't seem to be able to select a .conf file.
André (CLA, CLED)
(4,689 Views)
Accepted by topic author andre.buurman@carya
Hi Andre,
(The example on Github uses 'webvi_plugin' in the NXG example, and 'webapp_plugin' in the manual example. I primarily used the manually installed example, so use 'webapp_plugin' throughout my response).
1. To configure security/access control for all Web VIs in one place, modify the `52_webapp_plugin.conf` file, and duplicate the <Directory> tag to specify any other plugins. E.g.
<Directory htdocs/plugins/webapp_plugin/resources>
    # Tell the privilege module to use webapp_plugin.htpriv
	Session On
    AuthNIPrivilegeApplication webapp_plugin
    Require privilege ModifyResource
</Directory>
<Directory htdocs/plugins/webapp_plugin2/resources>
	Session On
</Directory> ​
2a. To change the name of the plugin in the SystemLink homepage, change the "pluginTitle" value within the en.json file –
htdocs\plugins\webapp_plugin\resources\json\locales\en.json
2b. To change the name of the application shown in the NI Web Server Configuration utility, change the <description> tag within the `webapp_plugin.xml` file. E.g.
<description xml:lang="en">Web Application</description>
To duplicate the webapp_plugin, you would also need to update a few other values with the config.json and en.json files. E.g.
C:\Program Files\National Instruments\Shared\Web Server\htdocs\plugins\webapp_plugin2\config.json
   "authorizationMarker": "/plugins/webapp_plugin2/resources/marker.txt",
   "buttonIconCls": "fa fa-area-chart",
   "buttonLabelToken": "webapp_plugin2.pluginTitle",
   "buttonTooltipToken": "webapp_plugin2.pluginTitle",
   "iframeResources": {
      "en": {
         "json": [
            "resources/json/locales/en.json"
   "iframeSrc": "plugins/webapp_plugin2/index.html",
   "orderWeight": 2,
   "permission": "",
   "resources": {
      "en": {
         "css": [
            "plugins/webapp_plugin2/resources/css/webapp_plugin.css"
         "json": [
            "plugins/webapp_plugin2/resources/json/locales/en.json"
   "routeToken": "webapp_plugin2",
   "titleToken": "webapp_plugin2.pluginTitle",
   "waitUntilLaunched": false
C:\Program Files\National Instruments\Shared\Web Server\htdocs\plugins\webapp_plugin2\resources\json\locales\en.json
   "webapp_plugin2": {
      "pluginTitle": "Web Application 2"
3. You should be able to rename the file from within the Project Files pane in NXG. Right-click > Rename.
4. You should be able to import new conf files in the same way. Right-click `support files` > Import file…
Hope this helps!
Fred Visser -- SystemLink R&D -- National Instruments
(4,638 Views)
Thanks Fred, this helps tremendous.
Would it be something to add to the readme in the Github repo?
I will try and add a new file to a webvi dist using a new project started in NXG 4, the example was a converted project from NXG 3.1
There a few annoyance for me with NXG 4's performance compared to 3.1, I'm hoping the next release will provide a better experience on some topics. Since it's so cose I'll check when it's released and provide in app feedback when it's still an annoyance/problem.
André (CLA, CLED)
(4,613 Views)
