SystemLink Forum
SystemLink Server Installation Fail
The first link really helped, thanks for sharing!
Message 11 of 15
(2,038 Views)
@Justin_E wrote:
Can you turn Package Manager logging on and retry the SystemLink Server installation?
1) Open an administrative command prompt to C:\Program Files\National Instruments\NI Package Manager
2) Run nipkg config-set nipkg.plugin.wininst.msilogs-enabled true
3) Run nipkg config-set nipkg.plugin.wininst.msilogs-directory=c:\
myprepaidcenter activation
  • Change c:\ to whatever directory you want to log files to
Once you retry the installation and see the RabbitQM Configuration error, please zip up the logfiles and attach them here
ya but what do to next..
Message 12 of 15
(2,030 Views)
Trying to install LabVIEW NXG5.0 and LabVIEW 2020 64-bit.
I can not install tools that require RabbitMQ (SystemLink, NXG FPGA etc.)
The error:
uninstalling rabbit from Package Manager and from windows installer (incl erlang) and reboot did not help.
I have no antivirus programm except from windows.
I also opened LabVIEW NXG, worked a bit and waited for one day.
I still can not install products because they all stuck when installing rabbitmq support.
attached the logfile from package manager.
Message 13 of 15
(1,947 Views)
Hi clicks,
the error log targets towards a faulty registry key of rabbitmq. Another customer could fix the issue with the following steps:
Open Regedit.exe
·        Browse to HKEY_LOCAL_MACHINE\SOFTWARE\Ericsson\Erlang\ErlSrv\1.1\RabbitMQ
·        Remove that key
Fabian Wehnekamp
Senior Technical Support Engineer
Message 14 of 15
(1,870 Views)
I have been trying to upgrade to LabVIEW 2020 and get the same message and a failed install. Log file is attached. Any help would be appreciated.
Message 15 of 15
(1,853 Views)
