SystemLink Forum
Goal: read tags using python library
Situation:
  • Self-hosted systemlink server
  • Using python with http configuration using login username and password
  • Trying to read tag using https://corp.com/nitag/v2/tags/[TAG NAME]/values/current/value
  • 401 unauthorized error through python
  • 401 unauthorized error through browser using same login
  • Can view tag and value in systemlink web gui using same login
  • Access control tab for one of the user roles allows all privileges for tags
Is there a special access control setting for using the web api? Why can I see a tag in the gui and not access it through the api with the same creds?
(2,208 Views)
(2,203 Views)
nisysmgmt/v1/systems works
(2,200 Views)
https://systemlink/nitag/v2/tags/[WORKSPACE]/[TAG]
Works on browser!
But there doesn't seem to be a way to hit this endpoint in the python library?
(2,179 Views)
Have you tried to use the SystemLink Python API?
https://python-docs.systemlink.io/en/stable/getting_started.html#tag-api
(2,149 Views)
Also are you using SystemLink Server or SystemLink Enterprise. Enterprise has a different API end point than the web server, so it requires a different URL.
(2,147 Views)
