SystemLink Forum
Analysis Automation - nitdmreader.MetadataApi error
I'm working on an analysis automation and starting with understanding the following example: https://github.com/ni/systemlink-server-examples/blob/master/jupyter/analysis-automation/BasicExampl...
However, when I attempt to execute the following chunk:
(372 Views)
I was able to figure it out. Apparently the ni_analysis_automation variable that is populated when the Jupyter notebook is executed by the automation routine, does not have the correct session variable.
In order to resolve this I extract the ids from the list of files in the passed in variable, then reconstruct the file list:
import urllib.parse as ulp
import json
id_values = []
for link in ni_analysis_automation['data_links']:
    parsed = ulp.urlparse(link['fileId'])
    query_params = ulp.parse_qs(parsed.query)
    # The 'query' param is a JSON string, so we need to load it
    if 'query' in query_params:
        query_json = json.loads(query_params['query'][0])
        # Extract the id value
        id_value = query_json.get('test', {}).get('id', None)
        if id_value is not None:
            id_values.append(id_value)
payload = {
    "variables": {
        "$URL": {
            "stringArray": {"values": f"corbaname::#{datafinder_name}.ASAM-ODS"}
headers = {
    "x-ni-api-key": systemlink_api_key,
    "Content-Type": "application/x-asamods+json"
session_response = requests.post(
    f"{systemlink_uri}ni/asam/ods",
    json=payload,
    headers=headers,
    verify=cert_path
session = session_response.headers.get("Location")
file_ids = [f"dfs:/?url={session}&query={{\"test\":{{\"id\":{id_val}}}}}" for id_val in id_values]
# Call metadata service (for example)
file_infos = await metadata_api.get_multiple_file_info(tdmreader.FileList(file_ids))
Is this really the best solution? This is all that I could come up with.
(343 Views)
