Switch Hardware and Software
how to activate a valve with a switch ?
I am going to work on the automation of a miniature punch press using compressed air and also a pneumatic valve, I was wondering how I would be able to activate this mechanism with a switch?
Also, what would be the best method to activate this set up ?
(6,618 Views)
Can you provide more information about the valve itself?  For example, is it expecting an analog signal or a digital signal?  If this is an analog setup, the valve would probably expect a DC value that represents a certain pressure.  You would need a variable voltage source (a DAQ card for example) to provide the appropriate signal to the valve.  A switch would most likely not be necessary.  If the valve is expecting a digital signal, then you will need a DC power supply set to the digital high voltage (5V for example) and then use the switch to regulate the state of signal.
(6,607 Views)
If you can choose your own valves, I would go with a 4-20mA controller. It very inexpensive for the HW from NI, and it works like a champ. If you already have your valve, most companies offer the 4-20mA option on controllers, it is very versatile, fast, and VERY accurate with settings.
One should welcome adversity as an opportunity to excel.
(6,561 Views)
