Switch Hardware and Software
PXI Switch Module
How do I detect the Switch module present in PXI Controller. I am programming in lab veiw RT 7.0 version.
I also need to find the device number and the slot info of the device present in RT controller programmatically.
How do I achieve this. Is there are any issues programming switch modules in Real time .
Suresh Thangappan
(6,613 Views)
Suresh,
Your RT controller should have NI-DAQ 7.3 or later installed. Once NI-DAQ is installed, install your switch modules and restart your controller under RT. On your host computer, expand "Remote Systems", and under the IP adress of your RT controller you will see all the switches you have installed.
(6,600 Views)
