Switch Hardware and Software
PXI-2529 RF Switch
The PXI-2529 is a 4to1 RF mux. It is made up of 5 SMA's, Four inputs and one COMMON output.
My question is "Can the input be on the COMMON SMA connector and the output be the other four SMA's? In other words, can this switch be operated as a demux?
If the switch is used as a demux, will it still have the same RF characteristics?
Thank you.
(6,427 Views)
Hey R,
The PXI-2529 is a high density matrix, but yes, you can use our RF muxes (PXI-254x, PXI-255x, PXI-259x) as 'demux' modules.  Note that RF multiplexers with termination (2597, 2545, 2555) are only terminated on the channel side, so you will not be able to terminate the COM channel internal to the module; you can simply terminate one of the output channels and then hook COM to that channel if you need to be able to terminate the COM path.  Have a great day!
-John Sullivan
Problem Solver
(6,425 Views)
Mr. Knight,
You are correct, I meant PXI-2595 RF Switch.
Thank you,
R
(6,423 Views)
Hey R,
The 2595 is not terminated internally, so can be used as a 4x1 exactly the same as a 1x4.  Have a great day!
-John Sullivan
Problem Solver
(6,420 Views)
