Switch Hardware and Software
I have installed Switch Exec 2.1, running LabVIEW 8.2 and none of the VI's appear on my functions palette
See subject line.
Chris
One should welcome adversity as an opportunity to excel.
(6,872 Views)
Hi Daddy-O,
NI Switch Executive 2.1 doesn't install support for LabVIEW 8.2. If you want to use NI Switch Executive with LabVIEW 8.2, install support for LabVIEW 7.0, 7.1 or 8.0 and then manually copy the appropriate files to the LabVIEW 8.2 directory.  The procedure to copy the appropriate files is explained in the following KnowledgeBase:
Installing NI Switch Executive for LabVIEW 8.2
http://digital.ni.com/public.nsf/websearch/3D6BA1DB032CA23986257203004F5A98?OpenDocument
Let me know if you have further questions!
Chad Erickson
Switch Product Support Engineer
NI - USA
(6,870 Views)
Thanks Chad that was the fix I was looking for...Smiley Happy
(6,863 Views)
