11-16-2007 10:04 PM
11-19-2007
11:38 AM
- last edited on
05-06-2024
01:45 PM
by
Content Cleaner
FET switches such as the SCXI-1128 will have a faster scan rate and lower power requirements than mechanical relay switches such as the SCXI-1127. The advantage of using a mechanical relay is the amount of current it can switch and carry. You should base your decision on the specifications of your input signal and how fast you will eventually need to scan through the channels.
The two wires from each shunt will connect to the terminal block (which will have inputs corresponding to the channels of your switch module) and the DMM will connect to the output of the switch module (through the terminal block). Scanning through the channels will connect one channel to your output (DMM) at a time. The DMM will then average the voltage measurements to provide a more accurate reading.
