This error often occurs when I run labview-tx-vi with USRP2, I didnot know why. Could you please tell me the reasons?
I have seen this before on the USRP2. Please ensure you are using the latest firmware. Also if you are able to reproduce the error using a certain set of steps please let us know and it may be something that we could address.
Does it happen every time or just occasionally?
Note, only the NI USRP-292x and NI USRP-293x devices are offically supported and have been fully tested with NI USRP Driver. Other device such as the USRP2 are not offically supported by the driver.
Erik
Hi! I checked my firmware,and it's the latest version.
1. Installing the software:
Labview 2012
Labview Modulation Toolkit 4.3.1,
LabviewLabview Digital Filter Design Toolkit,
Labview MathScript RT Module,
and NI-USRP 1.2.
2. Default IP Address:
Host Ethernet Interface IP Address 192.168.10.1
Host Ethernet Interface Subnet Mask 255.255.255.0
Disable the firewall settings
I use USRP2 with the RFX2400 daughter board,
The tx parameters are as follows.
I only changed tx frequency and tx antenna. After I run the program for a few seconds, the following error appeared.
It happens almost every time.
The program only succeeded occasionally when I run the program on a better computer.
Thank you for the additional detial. The RFX2400 has not been tested. It is likely that there is a settling time for the oscillator that exceeds the default built into the driver. Our driver defaults were tuned for use with the XCVR2450 and SBX in the 2.4 gHz band.
