Transmit / Receive Video between a pair of USRPs
I would love to see an example based on the packet-based link example. Where after every package the carrier frequency is change. This frequency hopping is used in bluetooth. The problem is that the niUSRP Configure Signal.vi is not allowed inside loops.
Thanks for the suggestion. The niUSRP Configure Signal.vi can actually be used inside a loop--you just can't call it when a continuous acquisition is active. You can, for instance, call it to set a new carrier frequency / etc. after halting a continuous acquisition or completing a finite acquisition.
Either way, I think an example is a good idea to show how this can be done.
Begining with NI-USRP 1.1 (releasing this month) you will be able to use Configure Signal VI while the device is generating or acquiring (i.e. in your acquisition loop), as long as you don't change the IQ Rate. Carrier Frequency, Gain, and Active Antenna will all be reconfigurable while the device is running.
These are some great news. Can't wait for the usrp 1.1. ![]()
NI-USRP 1.1 Released!
https://www.ni.com/en/support/downloads/drivers/download.ni-usrp.html#306987
Hi sshearman,
This is YoungMin from NI Korea.
I would like to see an example of OFDM siganl generation and decoding as many of my customers want to realize OFDM based applications for teaching, research as well.
Can you provide OFDM generation code with 3~5 subcarriers and users can change subcarriers modulation scheme such like that?
And I think phase coherence compensation code is also necessary for those who want to realize MIMO system.
Thanks!
hi sshearman, YYY, et all,
related to frequency hopping, it´s possible in continuous rx but you have to stop reconfigure and start and of corse this will cost time. You can find an example of an application working in http://sine.ni.com/cs/app/doc/p/id/cs-14513
for help plese email: jcarlosvgr@av.it.pt
How can I synchronize transmitting and reception of 2 USRP by MIMO cable?
I want to begin transmission and reception at the same time.
Something like Vector Network Analyzer - synchronized input and output, both first transmitted and first received sample at the same time.
THX
Hi, I´m new with the USRP 2920 and I need some explanation please about Lab3:synchronization, because I have an error with MIMO link, but I don´t want use MIMO because I have only 2 transceivers, the question is How can I synchronize transmitting and reception of 2 USRP without MIMO cable?
Please post all LabVIEW + USRP technical support requests here:
http://forums.ni.com/t5/USRP-Software-Radio/bd-p/500
(These forums are monitored by NI RF Support Engineers)
Spectrum Monitoring and Signal Detection with NI USRP
802.15.4 transreciver
Have you checked out this one:
Automatic Modulation Classification using Cyclic Feature Detection
OFDM of QAM generated signal with niUSRP
Hi sshearman,
I am looking for an example On-Off Keying modulation TX and RX VIs for USRP. I have not found any example related to it. I would really appreciate if you or someone else post them.
JK
Hello mishrashirish,
A new example has been added to the code sharing community. It is an continuous OFDM TX and RX program. QAM modulation is supported and the symbol map can be modified by unbundling MT Generate QAM VI system parameters output.
Hi sshearman,
I am looking for an example Manchester Encoding TX and RX VIs for USRP. I have not found any example related to it. I would really appreciate if you or someone else post them.
JK
Would you provide an example such as communication between two USRPs using FDD or TDD?Because I think it will be very helpful for us.I am not familiar with the method the USRP use to control the transmmiting and receiving time.Thank you.
Try this ALOHA MAC - TDD example.
http://forums.ni.com/ni/attachments/ni/500/1230/1/ALOHA%20MAC.zip
Erik
I run the main.vi.But it told me that the '"IMAQ Flatten image to String" does not exsist.Are there something that I need to install before I run this project?Thak you.
can you provide an example of relay (tx and rx where relay are the bridge for that tx and rx) for mimo OFDM?
Could you please provide a VI using 8 bits quantization level instead of 16 ?
Laura.
If you check inside the folder
Start Menu -> All Programs -> National Instruments -> NI-USRP -> Examples -> LabVIEW
it will open a folder with many examples. Find the one named
niUSRP EX Rx Customize Fetch Type and Sample Width.VI for a reference program using 8-bit mode.
Laura.
Hi sshearman,
I am looking for an example VI implementing IEEE standard 802.15.7
http://standards.ieee.org/findstds/standard/802.15.7-2011.html
JK
Hi sshearman,
I would like to have a QpSK TX/RX design that at 2.4 ghz please if you have such a design send it to me
I'm mahmood adel from Iraq working on Ettus N210
best egards
Are you find why implement 802.15.7 in Labview ?
Tank,
We're using the 2944R's. For those of us who do the bulk of our dsp on the fpga (for throughput & latency,) a simple repeater would sure be a nice example. It would give us something to build on. The Simple Streaming example is better suited to host side dsp. And flattening it has not been easy.
