I am a college student currently working on designing a multi-hop relay network.
We did not run the program based on USRP2932, but LED E remains in a Blink state,
and if you connect several devices using an unmanaged gigabit Ethernet switch, there is a problem of recognizing only one.
If you know the solution, please leave a message and I would appreciate it.
* attach the LED status and the currently in use Firmware as follows.
