This example demonstrates RF record and playback using the NI USRP™ tranceiver.
For complete description and details for the following example, check out this white paper:
https://forums.ni.com/t5/Example-Program-Drafts/Record-and-Playback-Demo-With-NI-USRP/ta-p/4099379
1. Open Record.gvi and navigate to the front panel
2. Populate the front panel controls as follows:
3. Run the VI to record a signal with the configured settings
In our demonstration using a handheld two-way radio, the parameters were configured and input was observed/recorded as shown in Figure 1:
Figure 1: Front panel parameters for recording of two-way radio
NOTE: Be sure to observe the coerced values so that you know exactly what parameters were used for the recording
4. Open Playback.gvi and navigate to the front panel
5. Populate the front panel controls with the File Path to the previously recorded binary file, as well as the Carrier Frequency, IQ Rate, and Gain used previously (assuming you're playing back to the same device you recorded from)
6. Run the VI to playback the recorded signal with the configured settings
The parameters were configured as shown in Figure 2 for playback of the two-way radio signal recorded for this demonstration:
Figure 2: Front panel parameters for playback of recorded two-way radio signal
See the full Record and Playback tutorial for LabVIEW 2014: http://zone.ni.com/devzone/cda/tut/p/id/13881
LabVIEW 2014 version of this example is available here.
hello
can I use the RF Record-Playback Communications.zip 23 KB for monitoring if gsm signal in GSM 900 band to find the channel efficiency...???? please help...
if not can You provide gsm signal receiving vi ...........in labview using usrp2920 kit..
hi
I am using labview 2017 and the above rf record playback .zip , iam not able open in labview 2017 in windows platform ,
please suggest how to open that files in labview 2017.
regards
Ekula srinivas
I am using LAB view 2020 64 bit with USRP Ni 2900
I try to use RF Record-Playback Communications.zip 23 KB , but it is not open in my labview...
currently i am using another NI USRP Record and Playback - I16.llb 219 KB
I am using RX2 for recording through an active antenna mounted on roof with a feeded bias tee
it is making .bin file but not showing any GPS satellite
I m suing 1575.42M, IQ rate 4M and gain 20dB
