Software Defined Radio
Need SDR + LabVIEW Technical Support?
Please post all LabVIEW Communications System Design Suite + SDR technical support questions here:
http://forums.ni.com/t5/LabVIEW-Communications-System/bd-p/540
and post all LabVIEW + SDR technical support requests here:
http://forums.ni.com/t5/USRP-Software-Radio/bd-p/500
(These forums are monitored by NI RF Support Engineers)
Comments
rajendra88
Member
Member
on
If i want to make 2x2 MIMO than how many USRP module need ??
I have USRP 2920 module.
Can I Make The Transmitter and Receiver with the single Module ?
Romaro
Member
Member
on
for 2920 USRP to build 2x2 MIMO you have to use 2 USRP Nodes , you can connect between them Using MIMO Cable that will provide the Connectivity and Synchronization between the Nodes .
Regarding your question about using both transmitter and receiver for the same node at the same time , actually it is possible , but there is no theoretical reference for that .
5G Researcher
Contributors
