Below are instructions for how to modify the Simple NI-USRP Streaming LabVIEW FPGA sample project to run with a Basic TX and Basic RX daughterboard installed. A modified sample project is also attached.
Hardware setup:
Basic TX and Basic RX installed on RF 1 (could be RF 0, chose side 1 arbitrarily)
Cabled TX SMAs to RX SMAs (Optional)
Software:
Note: The values on the front panel for Frequency, LO Frequency, Reference Level, and Output Power do not function because there is no hardware equivalent for these settings on the Basic daughterboards.
Thanks for the post Sarah. Always good to see more X310 examples. There was one more change that has to be made. I had to disable the error checking in "Decode Daughterboard Names.vi" in "niUsrpRio Config v1 Host.lvlib". That vi only has the code for wbx, sbx, or cbx boards. The library has to be unlocked first.
Good example!
My understanding is that an arbitrary wave, for instance waveform of center frequency lower than 1MHz, can be produced in this way just like an Arbitrary Waveform Generator. Is it Right?
Can this way be utilized to USRP RIO? My working platform is USRP 2943R.
Thank you.
