Signal Generators
labview code for generation of pulses like radar pulses inputting sine waves
dear sir,
kindly send me labview block diagram as simple as possible who could convert sine waves
(6,965 Views)
This is a duplicate post. Please refer to this link for further information.
In order to maintain the forums in an orderly manner and to keep problem solutions and information in a consolidated fashion easily searchable by customers, duplicate posts are often linked. Best of luck in future applications.
Jared T.
(6,958 Views)
Hi rafi,
Please disregard my previous duplicate post message for this thread.  If possible, let’s try to keep all questions and discussions to this thread.
It sounds like you are trying to generate sine wave pulses in LabVIEW.  Many of the LabVIEW example programs for outputting signals have been developed for specific hardware.  Without knowing your hardware, it is difficult to suggest which example program would be best for your application.  If you could post back with a more detailed description of your setup, that would make it easier for us to point you in the right direction.  Specifically, what hardware are you using? Are you acquiring any input signals? What version of LabVIEW are you using?
That being said, you can find example programs by searching keywords at ni.com or by using the LabVIEW Exampled Finder.  To access the example finder open LabVIEW then go to Help >> Find Examples.  Using the Example Finder you can access a wide range of example programs to get you started.
Are you doing something similar to this post?  If so, it recommends some good example programs
Jared T.
(6,933 Views)
