Signal Generators
divide trigger frequency
Hello everyone,
Does anyone know how can I divide the frequency of my external trigger?
(Instead of having a 100kHz trigger, i would like to have a 200 Hz trigger signal).
thank you all,
João Rodrigues.
(5,529 Views)
Which hardware do you use?
Regards
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(5,513 Views)
Thank you for your reply.
I am using an NI - PCI 6010 board and i am programming it with vc++ 2008.
My main purpose is to trigger an analog output waveform with 11 milliseconds. The thing is that my trigger has a frequency of 100 kHz, and many triggers will be received during those 11 milliseconds. Is there a problem or the board will ignore those signals and just look at the trigger after the task's execution?
If not, i should probably divide the trigger's frequency as aforementioned in my last question.
Thank you for your help Samuel.
João Rodrigues.
(5,511 Views)
