Signal Generators
Total available RFoutputs from RFSG
Is there any RFSG(Signal generator) having two RF outputs in single module.
(6,865 Views)
Hello Logesh,
Currently we do not have an RFSG device that has two RF outputs. The upconverter used with RFSG has a single output. Is there a specific application you had in mind that requires two outputs?
Chris Behnke
Sr. RF Engineer
High Frequency Measurements
(6,853 Views)
Hi Chris
                    I need to test RF Mixer IC for that i need two RF outputs from NI .i need RF & LO frequency to be generated.
Is there any other module with only continuous wave generation(no need of AWG) that can be as signal generator.Thanx for ur response.
(6,839 Views)
Hello Logesh,
We have three continuous wave sources, the PXI 5650, 5651, and 5652. We also have the 567x series of Vector Signal Generators, making use of an arbitrary waveform generator. All of these modules have a single RF output channel. In order to have two simultaneously RF output channels you would need to combine two of the above devices.
You can find out more about our RF devices here.
I hope that helps!
Chris Behnke
Sr. RF Engineer
(6,824 Views)
