Signal Generators
Simulating Signal Generators for different steam power plant parameters
I have been trying to do a simulation of different signals of a plant. I have used signal generators to simulate the speed signal and a few other signals in a preliminary VI I have created with a view to being able to log all the signals in the end.
The paramters are grouped into two sets and laid out on two tabs in the VI. I hve simulated the speed signal to go from 0 to the value specified as the setpoint. Most of the signals are digital switches (off/on) or analogue (0-100%).
My challenge is how to design a control loop to simulate the signals at once or can I just get on with generating indivisual signals for each parameter?
Thanks.
The parameters are grouped in two sets and laid out on two tabs as shown in the VI. I have simulated the speed signal to go from 0 to the value specified as the set point. Most of the signals are digital switches (either off or on) or analogue (0-100 % at any point in time)Is it possible for me to design a control loop to simulate the signals or can I just get on with generating individual signal for each parameter?
(6,578 Views)
Hi maxidivine,
I hope you are well and thank you for using the NI forums.
Are you wanting to just simulate signals? There are a number of vi's that will allow you to do this.
These include, in the Express VI palette, a vi called "simulate signals".
There are also numerous vi's that allow you to generate signals, such as the palette of Waveform generation within the signal processing palette.
Is it this information that you are looking for?
p.s. Nice looking front panel!!
Ashish Naik
Automotive Business Development Manager
National Instruments UK
(6,561 Views)
Thanks a lot Ashish. I have been able to simulate most of the signals. They went well.  I am working on general functionality of the software and data logging for the next phase. Thanks a lot for taking time to assist. This forum is fabulous.
(6,558 Views)
