Signal Generators
PGP-9 generator IEC-625/GPIB Help
Welcome. I`ve a PGP-9 generator and I would like to control it via interface IEC-625. I started sending command to him via VISA TEST PANEL. Everything is nicely sent. This can be seen on the generator panel : frequency, width, functions. When i program all functions I must send to generator GPIB "GET" command (ASCII code : BS ; hexadecimal : 08). Then the signal will appear on the generator output. I tried to type in the window "select or enter command" : \08 , BS, \b and it doesn`t give me anything. What do I have to enter to send the GET command to generator. Generator address is 7.
Message 1 of 1
(3,041 Views)
