Signal Generators
NiFGEN soft front panel error message
When I try to run NI-FGEN soft front panel, I get the following message:
"NI-FGEN for DAQ 2.3.0 was found, but it could not be loaded.  To run this software, you need NI-FGEN for DAQ 2.3.0 or higher."
I updated all of my drivers, and could not get rid of the error message.  The arbitrary waveform generator that I am using seems to work fine from within MAX and I have had no problems controlling it from LABVIEW.  Any thoughts?
(7,119 Views)
Hello Dave,
Can you please try the solution posted in the forum link below and let us know if it works:
http://forums.ni.com/ni/board/message?board.id=170&message.id=87130&requireLogin=False
Kalyan
Kalyanramu Vemishetty
Automated Test Systems Engineer
(7,103 Views)
Kalyan,
I tried reinstalling the driver, and that did not work.  Note also that I tried the "Repair" option on the driver and that did not work either.  I do have Administrator privledges on my computer also.  I will have an actual administrator log on to the administrator account to see if that solves anything.
Dave
(7,086 Views)
Hi Dave23
We think this error is related to the Traditional NI-DAQ installation. Please check the version of the nidaq32.dll file on your computer. (right-click properties) of <windows>\system32\nidaq32.dll.
If 'File Version' is not 7.768.3.1 (release 7.3) please try this:
Rename nidaq32.dll.  (ex: nidaq32.old)
Repair for Traditional NI-DAQ.
Go to Add or Remove Programs, Select National Instruments Software, and then select Traditional NI-DAQ 7.4.1 (Legacy) and click on the repair button.
Jerry
(7,074 Views)
