Signal Generators
NI driver for TEK AFG3000. Error message, "waveform structure out of use
I get an error message using the driver written by NI for the Tek 3000 arbitrary function generators.  "Waveform structure run out of use Elaboration: There are no free waveform structure to create new waveform.  What does this mean?
(6,569 Views)
Do you know which VI causes this problem? Is it a consistent problem? Could you possibly post an NI-Spy capture while this is running so we can see if there's any communication error or if this is an error caused inside one of the VIs.
Thanks!
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(6,561 Views)
