Signal Generators
MSP430 interface with DAC128S085EVM
Hi all,
I'm wondering if someone works with those boards mentioned above, when I opened the help tab of the  DAC128S085EVM I found its software is provided by NI, that is why I submit my question here, is someone know how to start generating nine dc analog signals simultaneously using this connection?
Thank you,
Sali
(4,137 Views)
Hi faislly,
Have you had the chance to check NI's Instrument Driver Network? Many third party instruments have drivers and examples posted there to help you get started.
(4,111 Views)
Actually I did not know that, but what is the keyword I should use when searching that website?
Thank you,
Sali
(4,109 Views)
If a set of pre-made LabVIEW VIs or driver for the device you are using exists, then you can browse by manufacturer, type, or search for the model itself as a keyword.
Otherwise, if you are using an interface such as GPIB or Serial, you can use the more general drivers NI-VISA, NI-448.2, and/or NI-Serial
(4,098 Views)
