Signal Generators
Is a there a calibration procedure for the PXI-6542?
I was wondering if there is a calibration procedure available for the PXI-6542.  I found a procedure for the 54xx models, but came up empty handed on 6542.
Brian Johnson
(7,088 Views)
Hi Brian
I had to check with a HSDigital expert.  They do not usually monitor the SigGen boards.
The PXI-6542 module does not require calibration and therefore does not have a calibration procedure.
If you have any further question, the Digital I/O forum is the best place to get results.
Jerry
(7,070 Views)
Didn't realize I was posting to the wrong board...
No calibration required is all I need to know.  Thanks for the quick reply.
Brian
(7,062 Views)
