Signal Generators
Incorrect RFSG Power Level
Hi, all:
I'm doing the RF record and playback example with 5661 and 5671 modules.
When re-playing, I found the output power level is incorrect and the level is variable with the different center frequency setting.
So, is there anything that I forgot to do?
由 marspop 在 02-12-2008 08:03 PM 上編輯的訊息
(6,833 Views)
Hello Marspop,
First of all, which example are you using, that might help in the troubleshooting.  One thing you might like to try is make sure you set the reference levels of the input/output correctly.  If that does not fix the problem, please let us know exactly what vi's you are using.
Benjamin Cook
(6,609 Views)
