Signal Generators
Implement active filter in LabVIEW using Orcad
Hello. My problem is as follows:
I have to generate a filtered signal using LabVIEW and NI-5411(Arbitrary Waveform Generator)(A sinus sweep from 10KHz to 100KHz in LabVIEW --> filter it in LabVIEW --> AWG NI-5411). The filter to use is an active filter designed with Orcad. I had thought of two choices: integrating somehow Orcad in LabVIEW or using a mathematical expression via a Formula Node to characterize that filter. The question would be how should I do it and how do I implement it.Just started working with NI5411, so any help would be really valuable. Thanks.
Message 1 of 1
(6,694 Views)
