Signal Generators
How i can configure cards for 56 Analog arbitrary output signals?
(6,438 Views)
You seem to be under the impression that you will be rewarded if your squeeze your entire question into the subject and now use the message body. That is not true. You really need to provide a lot of details. I, for one, have no idea what you are talking about.
Message Edited by Dennis Knutson on 02-05-2009 01:02 PM
(6,425 Views)
Thank you for your reply.
My task is as mentioned below in detail.
We need to provide 56 arbitrary waveforms individually to UUT.
This AWFG(Arbitrary waveform Generator) should be capable of operating up to 2.5 Ms/S.
We tried to check NI cards of up to this much capability but no success.
We found AFWG from Fluke with 4 channel capacity but it will lead to around 12 instruments which is not a feasible solution becoz we can't provide this much space in test stand.
So please support me any better solution.
(6,409 Views)
Are you planning to apply different waveforms at different times to the UUTs? Exactly how much space do you have?
I'm not going to do your google searches for you but you should be investigating VXI, PXI, and GPIB solutions.
Another possiblity would be for you to design a custom board. At the last place I worked, we used some custom cPCI boards to apply 96 independent signals to the UUTs. Each custom board had eight inputs. The downside is the time it would take to develop something from scratch.
(6,392 Views)
