Signal Generators
How do I Turn the RF On using the labview driver?
I am using an instrument driver to control my n5182a awg. The NI driver is PSGMXG which includes a output on VI. However, It isnt turning the RF output on...Is there a specific configuration order that I need to follow, or is there another VI that Im supposed to use?
Message 1 of 12
(9,721 Views)
ahmad88_76,
What VI's are you using now?  Also, have you looked at the examples included with the driver? Thy should be on your system at a location similar to: C:\Program Files\National Instruments\LabVIEW 8.6\instr.lib\Agilent PSG MXG Series\Example.
Eric K
Applications Engineering
Message 2 of 12
(9,680 Views)
Yes, I used 2 examples as references/guides. I'm able to configure everything else I need to so far. In order, I am using Initialize, RF Config, Config Arb, Arb Select, Config ALC, ALC Enabled, Sweep Config, Arb Enabled, Output Enabled, Output Mod. I spoke with agilent, and they insisted that they cant help me with labview drivers. I want to say that the DLL file within the Output Enabled VI is flawed, but Im not an expert.
Message 3 of 12
(9,678 Views)
Open MAX and turn on NI-Spy. Do a capture of when the Output Enable function is called. Open the trace data and compare the command being sent to the command that is in the manual. You could also execute the enable command in MAX and see if the output comes on.
There's also no dll involved. You can actually look at the code and modify it if necessary.
Message Edited by Dennis Knutson on 07-07-2009 08:01 AM
Message 4 of 12
(9,672 Views)
That was very helpful. Unfortunately, I realized that the SCPI command that was being sent to the instrument was 'OUTP:STAT 0' despite having toggled the enable switch on the RF Output vi. I couldnt figure out how to edit the vi, so i went ahead and sent the proper command using the GPIB vi. Thanks for your help in troubleshooting!
Message 5 of 12
(9,658 Views)
Why couldn't you edit the VI? Are you using the IVI driver instead of the LabVIEW driver?
Message 6 of 12
(9,653 Views)
This is the same problem I am having. Is there a driver that works or do we have to modify it ourselves?
Message 7 of 12
(8,979 Views)
Depends on which driver you are using. I looked at the project style driver and don't see a problem.
Message 8 of 12
(8,971 Views)
I am using the labview driver, downloaded from here
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=37333AE939A67126E0440003BA7CCD...
I actually started another thread about it in the labview section.
Message 9 of 12
(8,966 Views)
That link is meaningless. Please say whether you are using the LabVEIW plug and play or the LabVIEW IVI driver. You have to know which one you downloaded.
Don't start multiple threads!
Message 10 of 12
(8,964 Views)
