Signal Generators
Generate PWM Signal using PXI-5412
I'm using die PXI-5412 and I need to generate a PWM (rectangle) signal. The high level of this Signal should be 12V and the low at 0V. This should be the only voltage levels in the signal. The problem is that die max. offset of the PXI-5412 is +- 25% of the amplitude (Data sheet PXI-5412). In this case 3V.
Is there any possibility to generate this signal?
My aim is to build a .vi file to integrate this in Teststand.
(6,602 Views)
Hi Hannes,
Can you please post information about the load you are trying to drive using 5412? Is the load impedance 50 ohm or high impedance?
Kalyanramu Vemishetty
Automated Test Systems Engineer
(6,596 Views)
