08-07-2019 03:37 AM
Dears,
I need to build an Arbitrary Waveform from VI, then send to an Coil to generate a magnetic field. The waveform in the coil should have high current (1A) for generation of high magnetic field. What the device should I need? Device 1, device 2 ...?
LabVIEW VI generate Arbitrary Waveform ======> Device 1 (A/D) ======> Device 2 (D/A + Power amplifer) ======> Coil with high current (1A).
Thanks you!
09-06-2019 11:33 AM
How many connections does your coil need?
09-12-2019 08:48 AM - edited 09-12-2019 08:50 AM
Depending on the coil and frequency needed, 1A could be a 'high' current...
up to 100kHz a voltage controlled current source with a moderate power OP should do the job.
for more current :APEX power amplifier
Depending on the coil used and the frequency needed the voltage rating schould be the next question ...
If you want to buy a voltage to current amplifier you can look at BEAK, maybe phone them, I know the amps can do that.
