Signal Conditioning
pulse conditioning
hi,
I have a pulse train generated using a FOR loop and pulse pattern generator VI. The output plukse train is a 1D array. Please see the attachment. For all pulses, the width is fixed, which is 10 ms here. The fisrt pulse starts at time t=0 and ends at t=10 ms. The second one starts at t=2430 ms and goes off at t=2440 ms. The third one at 4720 and 4730 ms.
My problem is how I can modify the array such that the OFF time (only OFF time) becomes t/10. I mean, for the modified pulse train, the first pulse is 0-10 ms, second is 243-253 ms (start time -->2430/10), thris is 472-482 ms, and so on.
Can any one help ?
(6,045 Views)
I've knocked together an example VI (attached) which should perform this operation. Make sure you have a look through it and try to understand the logic as it will help you learn for tackling similar tasks in the future.
Let me know how you get on,
(5,912 Views)
