Signal Conditioning
pb with a function(need example)
i'm trying to use SCXI_Set_Config in vb and i have some problem... (hardware: pci 6024 + SCXI 1000+ SCXI 1520)
is ther any example on how to use this function in vb..i'm using it just to put my 1520 in parallel mode is there another way to do that??
thanx
Olivier
(3,373 Views)
Hello
You will have to use the Measurement and Automatioon Explorer to configure the 1520 in parallel mode, you wont be able to do it programatically. Check out this KB for details on how to do this.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,373 Views)
that's what i want to do first but i haven't the choice in "max" to select this mode... what can i do to get this option???
thnax
olivier
(3,373 Views)
