06-10-2010 09:15 PM
Hi All,
Is there any protection built into the circuitry of the SCXI-1540 so that if the primary winding of an LVDT short circuits then the excitation from the 1540 will not be destroyed.
kind regards
Frank Greenslade
Christchurch
New Zealand
Solved! Go to Solution.
06-11-2010 04:38 PM
Hi Frank,
The SCXI-1540 is supplying the excitation, thus the same amount of excitation is provided by the module even if the LVDT shorts. No additional current should be drawn. Hopefully this helps!
