Signal Conditioning
i am using the function generator example
i am using the function generator example to send sine, triangular, sawtooth waves to oscilloscope.
I would like to send not only the symmetric but also unsymmetric amplitude of each wave.for example the upper peak of the amplitude, i could adjust as 2 volts and the lower peak as 3 volts or vice versa.how it works in function genartor example.Please note the i am using data acquisition card AT- MIO-16XE-50 for this purpose.please tell me with some example.
(3,079 Views)
Hello Hood1,
in this VI you can choos offset. With offset you can chang the amplitude of your signal.
Regards
TN
(3,079 Views)
