Signal Conditioning
Using SCXI-1520 in Parallel mode
I am using LabVIEW 7.0 and DAQ ver. 7.0.
I am using PXI-1011 chassis with PXI-6070E DAQ Card and SCXI-1520 Module.
Till now i am am acquiring data using multiplexed mode. Because of the Sampling Rate issuesi want to shift to Parallel mode operation.
Specify the Steps for configuring the SCXI-1520 in parallel mode.
(3,387 Views)
Greetings,
You can setup the SCXI-1520 for parallel mode operation within Measurement and Automation Explorer (MAX).
Right-click on the PXI-1010 (SCXI) chassis within NI-DAQmx devices folder of MAX and select properties. Left-click the details button to the right of the SCXI-1520. Go to the cabling tab, and select parallel mode. This is all you need to do to set the SCXI-1520 to parallel mode.
I hope this helps. Let me know if you have any additional questions. Have a great day.
Todd D.
NI Applications Engineer
(3,387 Views)
