Signal Conditioning
USB-9213 Calibration question
I am considering purchasing a USB-9213 16 channel TC module but wanted to be sure that it could be calibrated in-house. The calibration procedure posted on NI website says it requires plugging the module into a NI cDAQ-9172 chassis to do this. My question is, can the calibration be performed over the USB connection instead or is there some additional features/connections in the backplane of the chassis that are not avaivable over the USB? Thanks.
(5,975 Views)
Hi hgcdte,
It is required for proper calibration to use a cDAQ Chassis.  The communciation is different enough that it would affect the calibration procedure.  Post back if you have questions!
Dustin D
(5,947 Views)
