Signal Conditioning
Signal Level Meter
Signal Level Meter
CATV Signal Level Meter GAO2002 is specially designed for CATV system maintenance. Signal Level Meter GAO2002 features small size (160mm x 130mm x 65mm) , light weight (368g including battery), long operating time (more than 6 hours), and well-built from appearance to architecture. Signal Level Meter GAO2002 combines the most practical functions and makes them easy to use. What is even better about this piece of equipment is that its added aseismatic design makes it more durable than you can expect. Tests show that it can continue to work well after being dropped from 5 meters high. It supports Level, V/A, Tilt and Trunk Level testing as well as testing two channels at the same time.
CATV Signal Level Meter GAO2002 Specifications:
Frequency
Frequency range: 46MHz ~ 860MHz
Frequency step: 50kHz, 1MHz, 10MHz and 100MHz
Level Measurement
Range: 20dBuV ~ 50dBuV
Accuracy: ±20dB (20ºC ± 5ºC)
Resolution: 0.5dB
Carrier to Noise (C/N)
Option Range: 20dBuV ~ 50dBuV
Input signal range: ≥ 85dB
Measure accuracy: ± 2.5dB (20ºC ± 5ºC) shut off the carrier
Resolution: 0.5dB
Voltage
Input range: 1~100V (AC/DC)
Measured accuracy: ±2V
Resolution: 1V
Miscellaneous
Size: 160mm x 130mm x 65mm
Weight: 368g (including battery)
Working: -10ºC ~ 40ºC
Audio: Built-in speaker (Auto on in single frequency mode)
Battery
Built-in battery: 3.6V/2.1AH Ni-MH
Working time: More than 6 hours (Shut off the audio and LCD backlight)
Charging time: 10 ~ 12 hours (power off)
Gao Tek Inc.
(5,983 Views)
Do you have drivers for LabVIEW?
(5,974 Views)
(5,974 Views)
