Signal Conditioning
SG24 cutoff frequency
Is it possible to get inside the module and set a lower cutoff frequency for the low pass filter?
This would void the warranty but I'd like to now if it can be done.
thanks
(3,684 Views)
Hi Nantizle,
The SCC-SG-24 has a set cutoff at 1.6 KHz.  If you need to isolate frequency components at a lower frequency range, I recommend using software filtering. There are a variety of FIR and IIR filters available in LabVIEW for this purpose.
Jennifer O.
(3,676 Views)
