Signal Conditioning
SCXi1000
Hi
I have problem with SCXi,
SCXi device is not working in XP operating system,Max detects the DAQ card but the when i run the LabVIEW program it gives the error message.
Any suggestions pls
(6,324 Views)
Hi Veeru,
You should make sure that the device is visible in MAX (Measurement and Automation Explorer)
Then you can configure the channels in your code to scan the channels as they are configured in MAX.
Hope this helps,
Steve
(6,273 Views)
