Signal Conditioning
Reading SCXI Serial Number
Is it possible to read the Serial Number of an SCXI-1124 or SCXI-1125 using software? I am not sure if the serial number is even located anywhere in the SCXI module firmware, but for tracking purposes we would like to be able to read this info on the host computer.
(3,798 Views)
Greetings,
I have not tested this information with SCXI, but you best would be to try the steps in the following KB:
http://digital.ni.com/public.nsf/websearch/AE521D8AEFD27E1E86256F9F007DF570?OpenDocument
Reply back if you have any questions!
Anuj D.
(3,787 Views)
I did try DAQmx and again with the VI on your link. The SCXI-1124 and SCXI-1125 devices return zero when reading the serial number property. The serial numbers for these devices are not displayed anywhere in MAX, so I question whether this information resides on the hardware at all.
(3,783 Views)
If your devices are returning zeroes for the serial number property, then the number is not stored on the EEPROM...
I was able to read serial numbers off of my 1102s with this method...
Sean C.
(3,775 Views)
