01-18-2006 04:07 PM
01-19-2006 07:39 AM
As a first guess YES
at least if it's wrong you get an error or really high readings
To be shure you can measure the ressistances between the wires: the same colored should give a low reading <1Ohm (depends on cable) and the two other will give 100(+x) Ohms. Compare it with the NI one and you have it.
01-19-2006 03:55 PM
