Signal Conditioning
RPM
I have a NI USB 4431 which would be the ideal sensor for RPM collection?
(3,339 Views)
USB 4431 is not an ideal device for tachometer application and is more suited to work with Accelerometers and Microphones better.
But if you have USB 4431 and want to repurpose it for RPM measurements, it may be possible but dependent on how you are going to measure the RPM.
Santhosh
Soliton Technologies
(3,315 Views)
Accepted by topic author Ricardo_Silva
The joy of engeneering is to do what you want with the stuff you can get 🙂
You want to measure RPM with a 4431 ...
How fast do you need to measure?
Is there a lower RPM boundary?   RPM=0 is always a hard task 😉
Accuracy needed?
Any sensors alrady there?  (pulse sensor ? incremental encoder ? )
Space conditions?  (not vaccum, just where to mount? Oil, dust, strong magnetic fields, ... ?
could be as simple as two resistors , and the magnet and reed relay from a bicycle tachometer 😉
Greetings from Germany
Henrik
LV since v3.1
(3,279 Views)
Hello Henrik,
Yes
Max. 1200RPM - Or it would be collection frequency rate, it doesn't need much precision.
No.
Accuracy needed?
I don't need to be too precise.
I have a pulse sensor.
Normal environment.
Thank you so much!!!
(3,272 Views)
