Signal Conditioning
Pressure transducer excitation connections
I am new to LabView and still learning many of the available features.
I have the following pressure transducer from Omega Engineering:
http://www.omega.com/pxconfig/pxconfig.html?pn=MMDWB250BIVK3D6T3A5S
NI Harware:
Output: SCXI 1325 w/ SCXI 1124
Input: SCXI 1328 w/ SCXI 1120
The transducer has the following wiring code avaiable:
 Pin 1: +Excitation pin 2: -Excitation pin 3: +signal pin 4: -signal
I have attached four wires from to the transducer. The - and + signals will terminate to the scxi 1328 terminal block. However, I am not completely sure how to connect the excitation voltage leads to the SCXI 1325 output. For each channel, I have four pins available: supply, i sink, vout, ground. I read the manual to know that the supply and i sink pins do not apply to my transducer. So, I am trying to figure out how to attach the - an + excitations since I have only v out and ground available. Has anyone encountered this before to know how to approach this? Thanks in advance.
(5,972 Views)
Hi Fromm,
As you said, the Supply terminal from the 1124 is no use in this case since it's a current source, not a voltage source like your sensor needs. What is the module of the Omega sensor you are using? The 1124's VOUT can drive up to ±10V @ ±5 mA (page 33-34 from the Manual and Specifications), and it will work for the 3 mV/V and 10 mV/V, but not the 0-5 Vdc model since it requires an excitation of 10 to 30 Vdc @ 10 mA. So basically you can wire VOUT and ground to the + EXC and - EXC on your sensor. If your model needs + 10V with more than 5 mA, then you could use a power supply.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(5,901 Views)
