Signal Conditioning
Measure distance
HI
Can someone help me
I want to measure in a white & Black image the coordinates.
The image is white and looks like an ellipse, and I want to measure the lenge and wide from  the Image.
I had thought I turn the image into an array, and a program to be an array read and in a form Boolien convert.
Then perhaps the program should lessen the coordinates into a WHILE LOOP always  add +1 to Koordinat, as long as array is still true
thanks
(6,632 Views)
you can find the solution direct in labview -> find examples -> toolkits -> vision -> circle distance.vi or in that link
http://zone.ni.com/devzone/cda/epd/p/id/5545
I attached you here the code (labview 8.2 or later with vision development toolkit) with screenshots where you can find the examples
Best Regards
(6,590 Views)
(5,615 Views)
